matrixdu   18-May-2025 08:47
james7991,
If problems with activating TZ (error ac ) do this
delete license file at C:\Program Data\CrypKey\Licenses folder and , also you need to delete serial_number file at folder C:\ProgramData\TimeZero\MetaCatalog
When you are done with that begin with all the activation process again
or
uninstall TZ v4
delete C:\ProgramData\CrypKey\Licenses
delete C:\ProgramData\TimeZero
RESTART computer
kill process crp32002.ngn if running
reinstall TZ V4.1.0.53 with a new serial number
or
1 - close Timezero
2 - open task manager and kill all the task running named crp320002.ngn
3 - delete folder C:\ProgramData\CrypKey\Licenses
4 - remove the serial number file in programdata/timezero/metacatalog
5 - Deactivate your internet connection
6 - launch again Τimezero and try again the activation.
7 - reactivate TZ with a new serial number and you should be back in business.
xyzoak   20-May-2025 19:24
Hello. I'm getting the error microsoft visual c++ runtime 12 could not be installed 5641186. I have runtime 12 installed. I tried uninstalling and installing again it doesnt work. I installed the most recent it doesnt work. I installed all runtime versions from 10 to most recent but I still get the same error installing timezero. Can anyone help? This never happened before. I also checked windows update and nothing.
kwaamsuk   20-May-2025 20:51
Cerrias,
Hi, I look for the unlock code for SDVJEWM227MAP28.dbv for my TZT Touch 14 first generation
I run software version 4.11
Please who can help me?
Thanks, regards, John
Vaniagulak887   23-May-2025 15:22
tomado, Здравствуй у меня вылазит ошибка кода генерирую ключ AC помогите разобраться
matrixdu   23-May-2025 15:48
Vaniagulak887, If problems with activating TZ (error ac ) do thisdelete license file at C:\Program Data\CrypKey\Licenses folder and , also you need to delete serial_number file at folder C:\ProgramData\TimeZero\MetaCatalogWhen you are done with that begin with all the activation process againoruninstall TZ v4delete C:\ProgramData\CrypKey\Licensesdelete C:\ProgramData\TimeZeroRESTART computerkill process crp32002.ngn if runningreinstall TZ V4.1.0.53 with a new serial numberor1 - close Timezero2 - open task manager and kill all the task running named crp320002.ngn3 - delete folder C:\ProgramData\CrypKey\Licenses4 - remove the serial number file in programdata/timezero/metacatalog5 - Deactivate your internet connection6 - launch again Τimezero and try again the activation.7 - reactivate TZ with a new serial number and you should be back in business.
luguoli1970   23-May-2025 16:36
TZ 132 has been installed successfully. Both C-MAP electronic charts and the S63 electronic charts from the China Maritime Safety Administration have been installed successfully and can be selected and opened normally. However, after shutting down and restarting the TZ electronic chart program, the computer screen shows that it has been cracked. Could you please advise, experts, how to solve this problem?
matrixdu   23-May-2025 17:20
luguoli1970, delete following
C:\Users\yourusername\Documents\Temp\{aaa3e21c64-63sdf25-1654e-zg1-0856410318}
C:\Users\yourusername\AppData\Roaming\Temp\{6f3e96c64-64f325-12ce-bhc1-08102bf10318}
C:\ProgramData\CrypKey\{4d36e96c-e325-11ce-bfc1-08002be10319}
C:\Users\yourusername\AppData\Local\Temp\{5e3e96c-e325-11ce-bfc1-08002be10319}
C:\ProgramData\Temp\{8f3e21c64-63f325-12ce-z5g1-081999f10318}
Kurkinmladshiy   01-Jun-2025 12:01
День добрый, пытаюсь поставить карту Sdvjewm227map29.dbv и не получается, установил map manager 2.7.1.0 , сделал ему update каталог, нашёл эту карту, а программа всё равно говорит что UC code не правильный, а он взят из map manager... В чем может быть проблема? Map manager ещё как-то настраивать нужно?
The time now is: Today 01:40
